Ga door naar hoofdinhoud
Sony Ericsson z300 Front Speaker Replacement
Wat je nodig hebt
  1. Sony Ericsson z300 Front Speaker Replacement, Back Phone Cover: stap 1, afbeelding 1 van 1
    • To remove the back cover, use your thumb to press down on the center of case and slide it off.
  2. Sony Ericsson z300 Front Speaker Replacement, Battery: stap 2, afbeelding 1 van 1
    • Using a fingernail lift the battery out of the phone.
  3. Sony Ericsson z300 Front Speaker Replacement, Front Phone Cover: stap 3, afbeelding 1 van 1
    • To remove the front cover, lift up the case with a fingernail in the small slot as shown.
  4. Sony Ericsson z300 Front Speaker Replacement, Front Dark Grey Case: stap 4, afbeelding 1 van 1
    • To remove the front grey case, remove the two screws shown with a T5 Torx Screwdriver.
  5. Sony Ericsson z300 Front Speaker Replacement: stap 5, afbeelding 1 van 1
    • Pry up the dark grey case with your fingernail until all four snaps around the top are loose.
  6. Sony Ericsson z300 Front Speaker Replacement: stap 6, afbeelding 1 van 1
    • Lift up towards the bottom and slide the case off.
  7. Sony Ericsson z300 Front Speaker Replacement, Screens: stap 7, afbeelding 1 van 1
    • Use a plastic opening tool to lift the black tape off of the ribbon cable connector.
  8. Sony Ericsson z300 Front Speaker Replacement: stap 8, afbeelding 1 van 1
    • Lift the ribbon cable connector lock using a plastic opening tool.
  9. Sony Ericsson z300 Front Speaker Replacement: stap 9, afbeelding 1 van 2 Sony Ericsson z300 Front Speaker Replacement: stap 9, afbeelding 2 van 2
    • Slide the black ribbon cable tray out with a plastic opening tool.
    • Shown in the second picture is the try already slid out.
  10. Sony Ericsson z300 Front Speaker Replacement: stap 10, afbeelding 1 van 2 Sony Ericsson z300 Front Speaker Replacement: stap 10, afbeelding 2 van 2
    • Slide the ribbon cable out of the connector.
    • Shown in the second picture is the cable already out.
  11. Sony Ericsson z300 Front Speaker Replacement: stap 11, afbeelding 1 van 1
    • Use a plastic opening tool to lift up on the screen board and release the clips holding it in place.
    • Lift the entire board out of the phone to remove both screens.
  12. Sony Ericsson z300 Front Speaker Replacement, Front Speaker: stap 12, afbeelding 1 van 1
    • Use a plastic opening tool to lift the speaker out of its circular slot.
Conclusie
Alex Serventi
65 Reputatie
13 handleidingen geschreven
Cal Poly, Team 5-15, Maness Fall 2010 Lid van Cal Poly, Team 5-15, Maness Fall 2010
CPSU-MANESS-F10S5G15
4 Leden
26 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 1,561
