Ga door naar hoofdinhoud
Inleiding
This guide will show you how to remove the Dark Grey case that allows you access to the Screens.
Onderdelen
Geen onderdelen opgegeven.
  1. To remove the front cover, lift up the case with a fingernail in the small slot as shown.
    • To remove the front cover, lift up the case with a fingernail in the small slot as shown.
  2. To remove the front grey case, remove the two screws shown with a T5 Torx Screwdriver.
    • To remove the front grey case, remove the two screws shown with a T5 Torx Screwdriver.
  3. iPhone Batterij Fix Kits
    Slechts $29.99
    Buy Now
    Slechts $29.99
    Buy Now
  4. Pry up the dark grey case with your fingernail until all four snaps around the top are loose.
    • Pry up the dark grey case with your fingernail until all four snaps around the top are loose.
  5. Lift up towards the bottom and slide the case off.
    • Lift up towards the bottom and slide the case off.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Alex Serventi
50 Reputatie
13 handleidingen geschreven
Cal Poly, Team 5-15, Maness Fall 2010 Lid van Cal Poly, Team 5-15, Maness Fall 2010
CPSU-MANESS-F10S5G15
4 Leden
26 handleidingen geschreven
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 0
Afgelopen 30 Dagen: 0
Altijd: 1,033
