Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Open the flaps and remove the back cover using the plastic opening device.
Remove the battery shield with the plastic opening device.
Unscrew the 5mm screws with the T5 head.
Unscrew the 6mm screw with the T6 head.
Remove the black cover with the plastic opening tool.
Remove the headphone jack from its slot.
Carefully pry the power cable away from the motherboard.
Remove the power cable from the backside of the motherboard.
The speaker can be seen in the top middle area on the reverse of the screen.
Use the plastic opening tool to carefully pry the speaker away from the phone.
