Ga door naar hoofdinhoud
Sony Ericsson xPeria Active Speaker Replacement
Wat je nodig hebt
  1. Sony Ericsson xPeria Active Speaker Replacement, Remove the back cover.: stap 1, afbeelding 1 van 3 Sony Ericsson xPeria Active Speaker Replacement, Remove the back cover.: stap 1, afbeelding 2 van 3 Sony Ericsson xPeria Active Speaker Replacement, Remove the back cover.: stap 1, afbeelding 3 van 3
    • Open the flaps and remove the back cover using the plastic opening device.
  2. Sony Ericsson xPeria Active Speaker Replacement, Remove inside plastic battery cover.: stap 2, afbeelding 1 van 2 Sony Ericsson xPeria Active Speaker Replacement, Remove inside plastic battery cover.: stap 2, afbeelding 2 van 2
    • Remove the battery shield with the plastic opening device.
  3. Sony Ericsson xPeria Active Speaker Replacement, Remove the battery: stap 3, afbeelding 1 van 2 Sony Ericsson xPeria Active Speaker Replacement, Remove the battery: stap 3, afbeelding 2 van 2
    • Remove the battery.
  4. Sony Ericsson xPeria Active Speaker Replacement, Unfastening The Motherboard Cover: stap 4, afbeelding 1 van 1
    • Unscrew the 5mm screws with the T5 head.
    • Unscrew the 6mm screw with the T6 head.
  5. Sony Ericsson xPeria Active Speaker Replacement, Removing The Motherboard Cover: stap 5, afbeelding 1 van 2 Sony Ericsson xPeria Active Speaker Replacement, Removing The Motherboard Cover: stap 5, afbeelding 2 van 2
    • Remove the black cover with the plastic opening tool.
    • Remove the headphone jack from its slot.
  6. Sony Ericsson xPeria Active Speaker Replacement, Speaker: stap 6, afbeelding 1 van 2 Sony Ericsson xPeria Active Speaker Replacement, Speaker: stap 6, afbeelding 2 van 2
    • Carefully pry the power cable away from the motherboard.
  7. Sony Ericsson xPeria Active Speaker Replacement: stap 7, afbeelding 1 van 1
    • Pry the motherboard out of the case.
  8. Sony Ericsson xPeria Active Speaker Replacement: stap 8, afbeelding 1 van 1
    • Remove the power cable from the backside of the motherboard.
  9. Sony Ericsson xPeria Active Speaker Replacement: stap 9, afbeelding 1 van 1
    • The speaker can be seen in the top middle area on the reverse of the screen.
  10. Sony Ericsson xPeria Active Speaker Replacement: stap 10, afbeelding 1 van 1
    • Use the plastic opening tool to carefully pry the speaker away from the phone.
Conclusie
Daniel
437 Reputatie
2 handleidingen geschreven
USF Tampa, Team 14-5, Leahy Fall 2014 Lid van USF Tampa, Team 14-5, Leahy Fall 2014
USFT-LEAHY-F14S14G5
3 Leden
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 11
Altijd: 862
