Inleiding
Sometimes, the screen can become cracked, damaged, or just simply not work. This can be frustrating, but never fear, as this replacement guide will make everything easier.
Wat je nodig hebt
Open the flaps and remove the back cover using the plastic opening device.
Remove the battery shield with the plastic opening device.
Unscrew the 5mm screws with the T5 head.
Unscrew the 6mm screw with the T6 head.
Remove the black cover with the plastic opening tool.
Remove the headphone jack from its slot.
Push the screen through the front of the case, gently.
It may be a little tough, just work your way around the edges of the screen until it separates from the main case.
5 andere personen hebben deze handleiding voltooid.
