Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Remove the four 6 mm screws from beneath the battery using a Phillips #00 screwdriver.
Remove the microphone cover using the iFixit opening tool.
Remove the two 6 mm screws from the front of the phone beneath the microphone cover using a Phillips #00 screwdriver.
Use the iFixit opening tool to loosen the motherboard from the phone.
Remove the two cable connectors using the iFixit opening tool.
On the rotational assembly remove the following screws:
Four 3 mm screws
Two 2.3 mm screws
Lift the rotational assembly off of the phone to allow access to the other half of the device.
Detach the cable connectors on the other end of the cables using a plastic opening tool.
Remove the plastic cover on the back of the phone using an iFixit opening tool.
Remove the four 6 mm screws using a Phillips #00 screwdriver.
Pry the screen assembly from the main case using the iFixit opening tool.
With the face plate and LCD screen exposed, replace the existing LCD screen with a new LCD screen.
