Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Remove the back cover by pulling it down, and then take out the battery.
Using a T6 Torx screwdriver, remove the 4 screws.
Keep the phone open with the back cover facing you.
Use the plastic opening tool and run it between the case and the body of the device to loosen the keyboard
Flip the phone over and lift straight up on the key pad to remove it.
Use the opening tool to remove the 2 ribbon wires (boxed in the photo) from the logic board.
Remove the black sim card reader and green vibrator before continuing to ensure they do not fall out.
