Inleiding
A guide to removing the camera on the Sony Ericsson Z500a.
Gereedschap
Onderdelen
Geen onderdelen opgegeven.
Use the i Pod opening tool to remove the 2 ribbon wires (boxed in the photo) from the logic board.
Close the phone, flip it over, grab the remaining gray covering of the phone and pull it straight up to remove it.
Once the cover is removed take off the black piece underneath.
To remove the plastic cover on the screen, run the ipod opening tool along the sides between the cover and the body of the phone (like you did for the keyboard)and gently pry upward until it is loose.
Like the keyboard there is one clamp on each side.
Grab the cover at the bottom of the screen (near the hinge) and pull outward while leaving the top (near the speaker) connected.
Once the bottom is pulled out far enough the top will be able to disconnect as well.
