Inleiding
Sony Ericsson X10 - how to disassemble the phone and replace the Touchscreen Glass.
Please SUBSCRIBE to my channel ツ
Video overzicht
  1. Switch-off the phone. Remove the battery. Unscrew 8x T6 Torx screws.
    • Switch-off the phone.
    • Remove the battery.
    • Unscrew 8x T6 Torx screws.
  2. Use a Plastic Pry or other plastic tool to unhook the back housing / bezel and remove it. Tip - try prying it open from the top and over to the side. It can be very tight if you are doing this for the first time. The volume rocker and camera button are not part of the housing, so try going around it. Tip - try prying it open from the top and over to the side. It can be very tight if you are doing this for the first time. The volume rocker and camera button are not part of the housing, so try going around it.
    • Use a Plastic Pry or other plastic tool to unhook the back housing / bezel and remove it.
    • Tip - try prying it open from the top and over to the side. It can be very tight if you are doing this for the first time. The volume rocker and camera button are not part of the housing, so try going around it.
  3. Gratis verzending van alle bestellingen van meer dan US$ 100,00 of met een Pro Tech Toolkit!
    Doorblader onze winkel
    Ooit iets gerepareerd? Je bent een genie.
    Deel je reparatie met #ImAGenius
    We zijn allemaal genieën
  4. Remove the Volume Up/Down and Camera buttons. Unhook the SIM & SD Card reader unit and disconnect the flex cable. Unhook the SIM & SD Card reader unit and disconnect the flex cable.
    • Remove the Volume Up/Down and Camera buttons.
    • Unhook the SIM & SD Card reader unit and disconnect the flex cable.
  5. Remove the Audio jack connector. Disconnect 4x flex cables: LCD Display
    • Remove the Audio jack connector.
    • Disconnect 4x flex cables:
      • LCD Display
      • Menu buttons
      • Touchscreen
      • Earpiece, Volume & Power On buttons
    • Carefully remove the mother board.
    • Please SUBSCRIBE to my channel ツ
  6. Use a heat gun or a hairdryer and warm the glass. With a cutter carefully make a room between the glass and the frame to insert a Plastic Pick. Slowly separate the Touchscreen from the frame.
    • Use a heat gun or a hairdryer and warm the glass.
    • With a cutter carefully make a room between the glass and the frame to insert a Plastic Pick.
    • Slowly separate the Touchscreen from the frame.
  7. When you are installing the new Touchscreen you must use an adhesive tape. .
Conclusie
Één andere persoon heeft deze handleiding voltooid.
ZFix
162.554 Reputatie
304 handleidingen geschreven
Master Techs Lid van Master Techs
Community
280 Leden
784 handleidingen geschreven
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 1
Afgelopen 30 Dagen: 8
Altijd: 1,402
