Inleiding
How to disassemble the phone and replace LCD Display.
Wat je nodig hebt
Video overzicht
Use a Plastic Pry or other plastic tool to unhook the back housing / bezel and remove it.
Tip - try prying it open from the top and over to the side. It can be very tight if you are doing this for the first time. The volume rocker and camera button are not part of the housing, so try going around it.
Unstuck the Touchscreen flex cable from the LCD Display Frame.
Disassemble the Home buttons flex cable & Plastic Bracket to release the Touchscreen Flex cable.
