Ga door naar hoofdinhoud
Sony Ericsson Xperia X10 Camera Replacement
Wat je nodig hebt
  1. Sony Ericsson Xperia X10 Camera Replacement, Camera: stap 1, afbeelding 1 van 2 Sony Ericsson Xperia X10 Camera Replacement, Camera: stap 1, afbeelding 2 van 2
    • To access the internal components, such as the camera, we need to flip the phone with the screen facing down. Once this is done remove the battery.
    Vraag FixBot
  2. Sony Ericsson Xperia X10 Camera Replacement: stap 2, afbeelding 1 van 1
    • Remove eight 5mm screws as shown in the image. Use a T-6 bit.
    Vraag FixBot
  3. Sony Ericsson Xperia X10 Camera Replacement: stap 3, afbeelding 1 van 1
    • Using a case opener, start on the bottom right side of the phone and undo clips located at the interior sides. Repeat this step for the left side.
    Vraag FixBot
  4. Sony Ericsson Xperia X10 Camera Replacement: stap 4, afbeelding 1 van 1
    • Once the clips are undone the back casing should dislocate and reveal the internal components of the phone. Camera location is identified on the image.
    Vraag FixBot
  5. Sony Ericsson Xperia X10 Camera Replacement: stap 5, afbeelding 1 van 3 Sony Ericsson Xperia X10 Camera Replacement: stap 5, afbeelding 2 van 3 Sony Ericsson Xperia X10 Camera Replacement: stap 5, afbeelding 3 van 3
    • To remove the internal case surrounding the camera, apply pressure on the left side of internal casing and using a flat head screw driver unlatch both clips on the right side of casing. Once lifted detach ribbon cable with flat head screwdriver.
    Vraag FixBot
  6. Sony Ericsson Xperia X10 Camera Replacement: stap 6, afbeelding 1 van 2 Sony Ericsson Xperia X10 Camera Replacement: stap 6, afbeelding 2 van 2
    • Once the interior casing is removed, dislocate the hardware by unlatching clip at shown location.
    Vraag FixBot
  7. Sony Ericsson Xperia X10 Camera Replacement: stap 7, afbeelding 1 van 1
    • To remove damaged camera flip hardware so the lens of the camera is facing downwards and remove ribbon cable connecting camera to hardware.
    Vraag FixBot
  8. Sony Ericsson Xperia X10 Camera Replacement: stap 8, afbeelding 1 van 1
    • Once camera is removed, insert new functional camera part and reassemble
    Vraag FixBot
Conclusie
Bryan
410 Reputatie
3 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 61
Altijd: 1,043
