Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Using a plastic prying tool, go around the outside of the phone releasing the plastic clips.
Remove the plastic housing revealing the motherboard
Remove the two Phillips screws.
Remove the headphone jack by carefully moving the dark plastic clip on the connector to 90 degrees
Remove the display connector marked in orange using a plastic spudger to pry it upwards
Remove the connector for the front buttons by prising the retaining clip to 90 degrees
Slide the metal frame across revealing the last screw . Make sure to keep the plastic cover after removing the screw
Disconnect the digitizer cable
Insert a plastic spudger around the edge of the frame and take the lcd assembely from the glass
Using a heat gun heat around the edges of the glass to soften the glue, and use your prying tool between the glass and the frame to take the glass off.
16 andere personen hebben deze handleiding voltooid.
