Ga door naar hoofdinhoud
Sony Ericsson W518a Camera Lens Replacement
Wat je nodig hebt
  1. Sony Ericsson W518a Camera Lens Replacement, Faceplate: stap 1, afbeelding 1 van 1
    • Find the small notch on the side of the phone. The notch is located by the "fast-forward" button and the "lock" switch.
  2. Sony Ericsson W518a Camera Lens Replacement: stap 2, afbeelding 1 van 3 Sony Ericsson W518a Camera Lens Replacement: stap 2, afbeelding 2 van 3 Sony Ericsson W518a Camera Lens Replacement: stap 2, afbeelding 3 van 3
    • Insert your plastic opening tool into the notch.
    • Pry off the faceplate by gently sliding the plastic opening tool around the phone while still keeping the tool under the edge of the phone.
    • When enough of the faceplate has been lifted it can be easily removed.
    • In order to replace the faceplate, simply press and snap the faceplate back onto the front of the phone.
  3. Sony Ericsson W518a Camera Lens Replacement, Camera Lens: stap 3, afbeelding 1 van 1
    • Remove the four 2mm Phillips screws from the back housing of the phone.
  4. Sony Ericsson W518a Camera Lens Replacement: stap 4, afbeelding 1 van 3 Sony Ericsson W518a Camera Lens Replacement: stap 4, afbeelding 2 van 3 Sony Ericsson W518a Camera Lens Replacement: stap 4, afbeelding 3 van 3
    • Insert the plastic opening tool in the notch at the top corner of the phone.
    • Lift the corner and run the plastic opening tool around the phone until the back housing can easily be removed.
  5. Sony Ericsson W518a Camera Lens Replacement: stap 5, afbeelding 1 van 2 Sony Ericsson W518a Camera Lens Replacement: stap 5, afbeelding 2 van 2
    • Remove the lends by pushing the lens from the inside of the housing.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
kgkramer
121 Reputatie
2 handleidingen geschreven
Cal Poly, Team 1-5, Regan SU 2012 Lid van Cal Poly, Team 1-5, Regan SU 2012
CPSU-REGAN-SU12S1G5
3 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 12
Altijd: 1,134
