Deze handleiding heeft recentere wijzigingen. Schakel over naar de nieuwste niet-geverifieerde versie.
Wat je nodig hebt
Place the phone face down on a flat smooth surface so that the camera, logos, and speaker face up.
Using the provided notch on the bottom of the back cover, insert a plastic opening tool and lift upwards to remove the back cover of the phone.
Flip the phone over and remove the Sony Ericsson sticker that is over the phone's ear speaker.
Using a T5 screwdriver, loosen and remove the two screws under the Sony Ericsson sticker by turning them counterclockwise.
Using a mini phillips head screwdriver, loosen and remove the screw located on the front number pad by turning it counterclockwise.
After removing this screw, the speaker will be free to move and the phone will look like this remaining picture.
To reassemble the phone, follow these steps in reverse order.
Één andere persoon heeft deze handleiding voltooid.
