Ga door naar hoofdinhoud
Sony Ericsson W200i Speaker Replacement
Wat je nodig hebt
  1. Sony Ericsson W200i Speaker Replacement, Disassembling Sony Ericsson W200i Battery: stap 1, afbeelding 1 van 2 Sony Ericsson W200i Speaker Replacement, Disassembling Sony Ericsson W200i Battery: stap 1, afbeelding 2 van 2
    • Slide the battery cover up and off the phone.
  2. Sony Ericsson W200i Speaker Replacement: stap 2, afbeelding 1 van 2 Sony Ericsson W200i Speaker Replacement: stap 2, afbeelding 2 van 2
    • Pop the battery out of its slot by lifting it up.
  3. Sony Ericsson W200i Speaker Replacement, Front Case: stap 3, afbeelding 1 van 3 Sony Ericsson W200i Speaker Replacement, Front Case: stap 3, afbeelding 2 van 3 Sony Ericsson W200i Speaker Replacement, Front Case: stap 3, afbeelding 3 van 3
    • Insert the plastic opening tool in between the front case and the back case.
    • Apply downward pressure to make the case lift upwards, thus popping the front case off.
    • Use caution when removing the front case. It may seem stuck but just ease it out.
  4. Sony Ericsson W200i Speaker Replacement, Core: stap 4, afbeelding 1 van 2 Sony Ericsson W200i Speaker Replacement, Core: stap 4, afbeelding 2 van 2
    • Remove the 4 screws in the corners of the front of the phone using a T6 screwdriver.
    • Note that the top 2 screws are silver and the bottom 2 screws are black.
  5. Sony Ericsson W200i Speaker Replacement: stap 5, afbeelding 1 van 3 Sony Ericsson W200i Speaker Replacement: stap 5, afbeelding 2 van 3 Sony Ericsson W200i Speaker Replacement: stap 5, afbeelding 3 van 3
    • There is a black tab in the top left corner holding the core in place.
    • Remove the core by pulling straight up to prevent breaking the tab.
  6. Sony Ericsson W200i Speaker Replacement, Back Case: stap 6, afbeelding 1 van 3 Sony Ericsson W200i Speaker Replacement, Back Case: stap 6, afbeelding 2 van 3 Sony Ericsson W200i Speaker Replacement, Back Case: stap 6, afbeelding 3 van 3
    • Pull back on the indicated tab of the white plastic cover to unhook it from the top of the phone.
    • Using the plastic opening tool, undo the indicated clip on the bottom of the white plastic cover.
    • Remove the white plastic cover.
  7. Sony Ericsson W200i Speaker Replacement, Speaker: stap 7, afbeelding 1 van 2 Sony Ericsson W200i Speaker Replacement, Speaker: stap 7, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Koop
    • Remove the speaker by pulling it up and out of place with the tweezers.
Conclusie
Andy Whitmyre
147 Reputatie
1 Handleiding geschreven
Cal Poly, Team 14-10, Forte Winter 2011 Lid van Cal Poly, Team 14-10, Forte Winter 2011
CPSU-FORTE-W11S14G10
5 Leden
16 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 6
Altijd: 4,845
