Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Pry off the plastic cover from the top with a thin plastic shim, then remove it from the two bottom clips.
After removing the screws, the two halves will separate. If not, then pry them gently apart.
Remove the circuit board and screen from the device.
Use your T6 to remove the 4 screws.
Carefully remove the plastic clips holding the screen on the board.
Gently pry it out the speaker located in the screen housing with a small screwdriver or similar tool.
