Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Begin the disassembly by placing your Sony Ericsson QuickShare T630 on a flat surface.
Slide the protective panel on the backside of the phone downward and remove it entirely, revealing the battery underneath.
Remove the rubber plug located near the camera by gently prying upward with your fingers.
Gently lift the camera shield after removal of the rubber plug.
Pry the remaining panel to loosen its contact to the phone using a spudger.
Slide the panel upward to remove it completely.
Remove the four screws located at each corner of the device.
Gently lift and remove the front panel of the phone after removing the screws.
Slowly lift the screen to reveal the green circuit ribbon connecting the screen to the phone.
Gently pull the ribbon from the circuit.
Remove the now disconnected screen.
Remove the keyboard by slowly pulling it away from the circuit board.
After wetting the cotton swab with the rubbing alcohol, rub the keypad with the swab until the buttons are clean.
Dry out the keypad by placing it on a flat surface before reassembling the device.
Purchase a new keypad and put it in place of the old keypad.
