Ga door naar hoofdinhoud
Sony Ericsson K750i LCD Screen Replacement
Wat je nodig hebt
  1. Sony Ericsson K750i LCD Screen Replacement, Battery Cover: stap 1, afbeelding 1 van 1
    • Remove the battery cover.
    • Press down firmly with your thumb and slide the cover back.
  2. Sony Ericsson K750i LCD Screen Replacement, Back Casing: stap 2, afbeelding 1 van 1
    • Remove two Phillips #0 screws from the battery chamber.
    • Remove two Torx T6 screws from the battery chamber.
  3. Sony Ericsson K750i LCD Screen Replacement: stap 3, afbeelding 1 van 1
    • Gently pry off the back casing.
    • Work an opening tool around the entire seam before attempting to pull off the casing. This action will reduce the chance of cracking the casing.
  4. Sony Ericsson K750i LCD Screen Replacement: stap 4, afbeelding 1 van 1
    • Remove the casing to expose the camera's components.
  5. Sony Ericsson K750i LCD Screen Replacement, Keypad: stap 5, afbeelding 1 van 1
    • Gently pry open the front casing by working an opening tool along the entire seam.
  6. Sony Ericsson K750i LCD Screen Replacement: stap 6, afbeelding 1 van 1
    • Remove the front casing by gently lifting it from the phone.
    • Be careful not to pull off any other delicate pieces.
  7. Sony Ericsson K750i LCD Screen Replacement: stap 7, afbeelding 1 van 2 Sony Ericsson K750i LCD Screen Replacement: stap 7, afbeelding 2 van 2
    • Remove the keypad.
    • The LCD screen is very fragile. Be careful not to catch the keypad on it while removing.
  8. Sony Ericsson K750i LCD Screen Replacement, LCD Screen: stap 8, afbeelding 1 van 1
    • Remove the screws holding the screen in place.
  9. Sony Ericsson K750i LCD Screen Replacement: stap 9, afbeelding 1 van 1
    • Gently lift the base of the keypad to remove it.
  10. Sony Ericsson K750i LCD Screen Replacement: stap 10, afbeelding 1 van 1
    • Gently pull up the green film, avoiding the joystick.
    • The LCD screen will be attached to this film and come off with it.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Abby Evers
202 Reputatie
6 handleidingen geschreven
UW Stout, Team 1-6, Zhou Fall 2011 Lid van UW Stout, Team 1-6, Zhou Fall 2011
UWSTOUT-ZHOU-F11S1G6
4 Leden
12 handleidingen geschreven
Één opmerking
Works perfectly, thank you guys!
Aurelien - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 11
Altijd: 4,046
