Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Flip to the back of the phone and locate the black button on the top of the phone.
Firmly hold down the black button on the top of the phone and gently snap off the back cover.
Remove the battery by wedging it out from the back.
Flip to the front of the phone and apply pressure to the front frame of the phone. The frame should snap off easily.
Remove the keypad by gently pulling it from the front of the phone.
Once the screws are off, there should be a plastic cover on top of your screen. Gently slide the plastic cover off.
You should now see the screen on the front side of the phone. Wedge your finger to the side of the phone. Apply some force to pop out the screen.
Now that screen is removed, replace the old screen with the new screen.
Reassemble the device by doing the steps in reverse order.
After removing the screen, you will find the charging port located at the bottom of the phone.
