Ga door naar hoofdinhoud
Sony DVP-SR200P Processing Board Replacement
Wat je nodig hebt
    1. Sony DVP-SR200P Processing Board Replacement, Top Cover: stap 1, afbeelding 1 van 2 Sony DVP-SR200P Processing Board Replacement, Top Cover: stap 1, afbeelding 2 van 2
      • Remove the five #1 Phillips screws (black, 3/16") attaching the cover to the DVD player.
      • One 3/16" screw on the right side of the DVD player.
      • One 3/16" screw on the left side of the DVD player (directly opposite of other screw).
      • Three 3/16" screws on the back of the DVD player.
      Vraag FixBot
      Voeg opmerking toe
    2. Sony DVP-SR200P Processing Board Replacement: stap 2, afbeelding 1 van 2 Sony DVP-SR200P Processing Board Replacement: stap 2, afbeelding 2 van 2
      • Slide the cover away from the front of the DVD player until it is off.
      Vraag FixBot
      Voeg opmerking toe
    1. Sony DVP-SR200P Processing Board Replacement, Processing Board: stap 3, afbeelding 1 van 1
      • Remove the blue tape from the processing board by gently pulling upward.
      Vraag FixBot
      Voeg opmerking toe
    2. Sony DVP-SR200P Processing Board Replacement: stap 4, afbeelding 1 van 2 Sony DVP-SR200P Processing Board Replacement: stap 4, afbeelding 2 van 2
      Gereedschap gebruikt in deze stap:
      • Use the tweezers to remove the four sets of wires connected to the processing board. Start with the cord located in front of the row of three cords.
      • The wires may be difficult to remove. Wiggling them while lifting them up may help remove them.
      Vraag FixBot
      Voeg opmerking toe
    3. Sony DVP-SR200P Processing Board Replacement: stap 5, afbeelding 1 van 1
      • Handle the processing board with care. It is fragile.
      • Unscrew the two #1 Phillips screws (silver, 3/16") located on the two edge corners of the processing board.
      Vraag FixBot
      Voeg opmerking toe
    4. Sony DVP-SR200P Processing Board Replacement: stap 6, afbeelding 1 van 1
      • Orient the DVD player so that you are facing the video and audio jacks.
      • Unscrew the two #1 Phillips screws (silver, 3/16") located on the outside of the DVD player
      • The processing board is now free to be removed and replaced.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Brian Hua
80 Reputatie
3 handleidingen geschreven
Cal Poly, Team 5-17, Forte Winter 2013 Lid van Cal Poly, Team 5-17, Forte Winter 2013
CPSU-FORTE-W13S5G17
5 Leden
72 handleidingen geschreven
3Gids Commentaar
I have Sony DVD player dvp at510p. After switching it runs then automatic Power go down while running it's process ic get hotter and hotter what's the right solutions plz help me
Dhiraj Vasave - Antwoord Deel
SO my DVD player run 5to 6 minutes then automatic stop all power goes to less
My DVD player not run but power on Bluetooth not connect
Sony - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 16
Afgelopen 30 dagen: 41
Altijd: 2,443
