Ga door naar hoofdinhoud
Sony DVP-FX730 Monitor Replacement
Wat je nodig hebt
  1. Sony DVP-FX730 Monitor Replacement, Cover: stap 1, afbeelding 1 van 1
    • Remove the five exposed 7.9 mm screws using a Phillips screwdriver.
    • Punch through the warranty sticker with the spudger.
    • Remove the screw underneath with the Phillips screwdriver.
  2. Sony DVP-FX730 Monitor Replacement: stap 2, afbeelding 1 van 1
    • Remove the rubber feet using the spudger.
    • Remove the screws that were covered by the rubber feet.
  3. Sony DVP-FX730 Monitor Replacement: stap 3, afbeelding 1 van 1
    • Hold on to the corners of the cover and gently lift the cover.
    • The tray is still connected to the base with wires.
  4. Sony DVP-FX730 Monitor Replacement: stap 4, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    • Gently remove the wires with tweezers by pulling up on the base they are attached to.
  5. Sony DVP-FX730 Monitor Replacement, Monitor: stap 5, afbeelding 1 van 2 Sony DVP-FX730 Monitor Replacement, Monitor: stap 5, afbeelding 2 van 2
    • Use your hand to remove the small back cover by gently pulling upward.
  6. Sony DVP-FX730 Monitor Replacement: stap 6, afbeelding 1 van 1
    • Using a screwdriver, remove the two 12 mm pan head screws.
  7. Sony DVP-FX730 Monitor Replacement: stap 7, afbeelding 1 van 1
    • The screen should now detach from the primary device.
    • The wires, indicated with a blue box, will still connect the screen.
  8. Sony DVP-FX730 Monitor Replacement: stap 8, afbeelding 1 van 2 Sony DVP-FX730 Monitor Replacement: stap 8, afbeelding 2 van 2
    • Remove the wires attached to the white base using tweezers to pull them up.
  9. Sony DVP-FX730 Monitor Replacement: stap 9, afbeelding 1 van 2 Sony DVP-FX730 Monitor Replacement: stap 9, afbeelding 2 van 2
    • Referring back to Step 8, do the same with the wires attached to the black base.
  10. Sony DVP-FX730 Monitor Replacement: stap 10, afbeelding 1 van 1
    • The screen should now be completely separated from the main device.
Conclusie
Andrew Ward
111 Reputatie
2 handleidingen geschreven
Cal Poly, Team 11-21, Maness Winter 2012 Lid van Cal Poly, Team 11-21, Maness Winter 2012
CPSU-MANESS-W12S11G21
4 Leden
5 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 13
Afgelopen 30 dagen: 47
Altijd: 3,243
