Ga door naar hoofdinhoud
Sony DVP-FX730 Cover Replacement
Wat je nodig hebt
  1. Sony DVP-FX730 Cover Replacement, Cover: stap 1, afbeelding 1 van 1
    • Remove the five exposed 7.9 mm screws using a Phillips screwdriver.
    • Punch through the warranty sticker with the spudger.
    • Remove the screw underneath with the Phillips screwdriver.
  2. Sony DVP-FX730 Cover Replacement: stap 2, afbeelding 1 van 1
    • Remove the rubber feet using the spudger.
    • Remove the screws that were covered by the rubber feet.
  3. Sony DVP-FX730 Cover Replacement: stap 3, afbeelding 1 van 1
    • Hold on to the corners of the cover and gently lift the cover.
    • The tray is still connected to the base with wires.
  4. Sony DVP-FX730 Cover Replacement: stap 4, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    • Gently remove the wires with tweezers by pulling up on the base they are attached to.
Conclusie
Rogelio Garcia
22 Reputatie
1 Handleiding geschreven
Cal Poly, Team 11-21, Maness Winter 2012 Lid van Cal Poly, Team 11-21, Maness Winter 2012
CPSU-MANESS-W12S11G21
4 Leden
5 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 42
Altijd: 1,641
