Inleiding
This guide is an important pre-requisite that is required to replace the Sony DSC-RX10M3 LCD and viewfinder. You will find in this guide the important steps required to make sure that you properly remove the back casing which exposes the motherboard of the device.
Wat je nodig hebt
Turn off the Device by scrolling the tab to "OFF" indicated by the arrow.
Remove the twelve 0.7mm Phillips #000 screws from the bottom case.
