Inleiding
The motherboard paramount for the proper function of the camera, basically acting like a "brain." This guide will serve as check for electronic connections, and a full removal procedure of this critical component.
Wat je nodig hebt
Remove all the 4.3mm screws on the bottom using a J000 Phillips screwdriver. There should be seven screws (4 silver, 2 black).
Remove all ribbon connectors from the motherboard using tweezers. Simply grab each ribbon cable and pull straight out of the connector.
There is a hidden wire on the bottom of the board that should also be removed.
In order to reassemble your device, follow these instructions in reverse order.
Één andere persoon heeft deze handleiding voltooid.
