Ga door naar hoofdinhoud
Sony DCR-DVD 108 LCD Screen Replacement
Wat je nodig hebt
  1. Sony DCR-DVD 108 LCD Screen Replacement, LCD Screen: stap 1, afbeelding 1 van 1
    • Remove the front facing screw adjacent to the LCD screen using a J1 Phillips screwdriver. The screw is 2.8 mm in length.
  2. Sony DCR-DVD 108 LCD Screen Replacement: stap 2, afbeelding 1 van 1
    • Rotate the camera screen until the screw on the bottom is clearly visible, then unscrew with a Phillips #1 screwdriver. This screw is 2.8mm in length.
  3. Sony DCR-DVD 108 LCD Screen Replacement: stap 3, afbeelding 1 van 1
    • Rotate camera again to find #1 Phillips head screw, the screw length is about 2.8 mm long. A J1 screwdriver is advised.
  4. Sony DCR-DVD 108 LCD Screen Replacement: stap 4, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    • Slowly pry apart the covers using a plastic spudger.
    • Be sure to disconnect the ZIF connector holding the ribbon cable in place. To do this, use a spudger to flip the black tab up, and pull the cable out with tweezers.
    • This photo shows a torn ribbon cable. Be sure to disconnect the ribbon cable before fully removing the LCD cover, to avoid damage to the device.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Elijah DeWolf
616 Reputatie
5 handleidingen geschreven
USF Tampa, Team 7-6, Cheng Spring 2016 Lid van USF Tampa, Team 7-6, Cheng Spring 2016
USFT-CHENG-S16S7G6
3 Leden
10 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 43
Altijd: 1,116
