Ga door naar hoofdinhoud
Sony DCR-DVD 108 LCD Screen Replacement
Wat je nodig hebt
  1. Sony DCR-DVD 108 LCD Screen Replacement, LCD Screen: stap 1, afbeelding 1 van 1
    • Remove the front facing screw adjacent to the LCD screen using a J1 Phillips screwdriver. The screw is 2.8 mm in length.
  2. Sony DCR-DVD 108 LCD Screen Replacement: stap 2, afbeelding 1 van 1
    • Rotate the camera screen until the screw on the bottom is clearly visible, then unscrew with a Phillips #1 screwdriver. This screw is 2.8mm in length.
  3. Sony DCR-DVD 108 LCD Screen Replacement: stap 3, afbeelding 1 van 1
    • Rotate camera again to find #1 Phillips head screw, the screw length is about 2.8 mm long. A J1 screwdriver is advised.
  4. Sony DCR-DVD 108 LCD Screen Replacement: stap 4, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    Koop
    • Slowly pry apart the covers using a plastic spudger.
    • Be sure to disconnect the ZIF connector holding the ribbon cable in place. To do this, use a spudger to flip the black tab up, and pull the cable out with tweezers.
    • This photo shows a torn ribbon cable. Be sure to disconnect the ribbon cable before fully removing the LCD cover, to avoid damage to the device.
Conclusie
Elijah DeWolf
577 Reputatie
5 handleidingen geschreven
USF Tampa, Team 7-6, Cheng Spring 2016 Lid van USF Tampa, Team 7-6, Cheng Spring 2016
USFT-CHENG-S16S7G6
3 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 15
Afgelopen 30 dagen: 37
Altijd: 707
