Ga door naar hoofdinhoud
Sony Cybershot DSC-W830 Motherboard Replacement
Wat je nodig hebt
  1. Sony Cybershot DSC-W830 Motherboard Replacement, Battery: stap 1, afbeelding 1 van 2 Sony Cybershot DSC-W830 Motherboard Replacement, Battery: stap 1, afbeelding 2 van 2
    • Open the battery cover by sliding it towards you.
  2. Sony Cybershot DSC-W830 Motherboard Replacement: stap 2, afbeelding 1 van 1
    • Push the purple latch with your thumb to unlock the battery.
    • Pull the battery out.
  3. Sony Cybershot DSC-W830 Motherboard Replacement, Front/Back Panels: stap 3, afbeelding 1 van 3 Sony Cybershot DSC-W830 Motherboard Replacement, Front/Back Panels: stap 3, afbeelding 2 van 3 Sony Cybershot DSC-W830 Motherboard Replacement, Front/Back Panels: stap 3, afbeelding 3 van 3
    • Remove the eight Phillips #000 screws.
  4. Sony Cybershot DSC-W830 Motherboard Replacement: stap 4, afbeelding 1 van 1
    • Remove the single Phillips #000 screw found next to the battery latch.
  5. Sony Cybershot DSC-W830 Motherboard Replacement: stap 5, afbeelding 1 van 2 Sony Cybershot DSC-W830 Motherboard Replacement: stap 5, afbeelding 2 van 2
    • Remove the middle panel on the side of the device.
    • Slowly pry the camera apart at its seem.
  6. Sony Cybershot DSC-W830 Motherboard Replacement, Lens: stap 6, afbeelding 1 van 3 Sony Cybershot DSC-W830 Motherboard Replacement, Lens: stap 6, afbeelding 2 van 3 Sony Cybershot DSC-W830 Motherboard Replacement, Lens: stap 6, afbeelding 3 van 3
    • Disconnect all ribbon cables by using the flat end of a spudger to lift up the black tabs on the ZIF connectors.
    • Once disconnected, use your fingers to lift lens out of the frame.
  7. Sony Cybershot DSC-W830 Motherboard Replacement, LCD Screen: stap 7, afbeelding 1 van 3 Sony Cybershot DSC-W830 Motherboard Replacement, LCD Screen: stap 7, afbeelding 2 van 3 Sony Cybershot DSC-W830 Motherboard Replacement, LCD Screen: stap 7, afbeelding 3 van 3
    • Lift the power button board up off of the daughterboard.
  8. Sony Cybershot DSC-W830 Motherboard Replacement: stap 8, afbeelding 1 van 1
    • Remove the single Phillips #000 screw.
    • Use your hands to remove the blue daughterboard.
  9. Sony Cybershot DSC-W830 Motherboard Replacement: stap 9, afbeelding 1 van 2 Sony Cybershot DSC-W830 Motherboard Replacement: stap 9, afbeelding 2 van 2
    • Flip the camera around.
    • Remove the black and orange ribbon cables.
  10. Sony Cybershot DSC-W830 Motherboard Replacement, Motherboard: stap 10, afbeelding 1 van 1
    • Remove the two remaining ribbon cables.
    • Pull the motherboard from the camera.
Conclusie
Saiman Sigdel
167 Reputatie
2 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 18
Altijd: 483
