Ga door naar hoofdinhoud
Sony Cybershot DSC-HX100V Control Button Sensory Panel Replacement
Wat je nodig hebt
    1. Sony Cybershot DSC-HX100V Control Button Sensory Panel  Replacement, Control Button Sensory Panel: stap 1, afbeelding 1 van 1
      • Make sure the camera is turned off.
      • Press the ON/OFF button to turn off the camera.
      • WARNING: Data may be lost if the camera remains on.
      Vraag FixBot
      Voeg opmerking toe
    2. Sony Cybershot DSC-HX100V Control Button Sensory Panel  Replacement: stap 2, afbeelding 1 van 3 Sony Cybershot DSC-HX100V Control Button Sensory Panel  Replacement: stap 2, afbeelding 2 van 3 Sony Cybershot DSC-HX100V Control Button Sensory Panel  Replacement: stap 2, afbeelding 3 van 3
      • Use the Phillips screwdriver size #00 to remove the 1.9mm #00 screws.
      • Remove 2 screws on the side of the camera.
      • Remove 4 screws on the bottom of the camera.
      • Remove 1 screw next to the eyepiece.
      Vraag FixBot
      Voeg opmerking toe
    3. Sony Cybershot DSC-HX100V Control Button Sensory Panel  Replacement: stap 3, afbeelding 1 van 1
      • Tilt the screen forward.
      • Remove the two 1.9mm #00 screws on the left with the Phillips #00 screwdriver.
      Vraag FixBot
      Voeg opmerking toe
    4. Sony Cybershot DSC-HX100V Control Button Sensory Panel  Replacement: stap 4, afbeelding 1 van 1
      • Pull the back part of the camera upward.
      • Use the spudger to help pry open the back panel.
      Vraag FixBot
      Voeg opmerking toe
    5. Sony Cybershot DSC-HX100V Control Button Sensory Panel  Replacement: stap 5, afbeelding 1 van 1
      • Open the back panel to view the inside of the camera.
      • Gently pull the orange ribbon cable to separate the two parts of the camera.
      • Set the back part of the camera aside.
      Vraag FixBot
      Voeg opmerking toe
    6. Sony Cybershot DSC-HX100V Control Button Sensory Panel  Replacement: stap 6, afbeelding 1 van 2 Sony Cybershot DSC-HX100V Control Button Sensory Panel  Replacement: stap 6, afbeelding 2 van 2
      • Turn the front part of the camera clockwise, so the lens is facing the right.
      • Gently remove the silver piece from the side of the camera. It should come out easily using your fingers.
      Vraag FixBot
      Voeg opmerking toe
    7. Sony Cybershot DSC-HX100V Control Button Sensory Panel  Replacement: stap 7, afbeelding 1 van 1
      • Remove two 3.38mm #00 screws from the sensory panel with a Phillips screwdriver size #00.
      • The first screw is located on the left side of the panel and the second screw is located near the top of the panel.
      Vraag FixBot
      Voeg opmerking toe
    8. Sony Cybershot DSC-HX100V Control Button Sensory Panel  Replacement: stap 8, afbeelding 1 van 1
      • Gently lift the orange ribbon cable with your finger to disconnect it.
      • Remove the sensory panel and replace it.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
5 andere personen hebben deze handleiding voltooid.
Sydney Counts
319 Reputatie
1 Handleiding geschreven
5Gids Commentaar
Where can you purchase this panel/
board?
Dana - Antwoord Deel
yes please. i need to fix my camera. thanks.
ploter64 - Antwoord Deel
I have issues when I turn the wheel to change the settings on manual mode. Would this be the same part?
Also, where can I find it? I tried to have it professionally repair and was told it needed the whole board and that it was not available any more. Thanks!
Ariel Donayo - Antwoord Deel
The exact same thing has happened with mine. This happened before but the camera was in warranty so Sony repaired it. It is longer in warranty now but has happened again.
Sam - Antwoord Deel
Sam, where did you find parts?
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 41
Altijd: 2,418
