Inleiding
Make sure you have the necessary tools in order to complete the motherboard replacement for the Sony Cyber Shot WX80 and be sure to have a steady hand when dealing with the smaller and more fragile parts.
Wat je nodig hebt
Remove all six #00 screws holding the outer chassis together with a Phillips #00 screwdriver.
Take note of the small free moving flap near the battery port seen in the first of the three photos.
Remove the front of the shell case with the spudger. Insert the spudger into the seam on the right side of the camera and pry away from the back case.
Using the spudger, repeat the process to remove the back of the case. Pry away from the front of the camera.
Use tweezers to remove the first of two ribbon cables holding the LCD screen in place. Pull directly out of the port.
Use tweezers to remove the second of the two ribbon cables using the same method.
The LCD screen is now detached. Gently pull it apart from the rest of the camera with your hands.
You should now be able to see the exposed motherboard and lens.
Remove the first ribbon cable (pictured first) with tweezers. Pull gently away from the camera.
Remove the second ribbon cable (pictured second) with tweezers. Pull gently away from the camera.
Use your fingers to gently lift the lens away from the motherboard and frame.
