Ga door naar hoofdinhoud
Sony Cyber-shot DSC-WX80 Lens Replacement
Wat je nodig hebt
  1. Sony Cyber-shot DSC-WX80 Lens Replacement, LCD Screen: stap 1, afbeelding 1 van 3 Sony Cyber-shot DSC-WX80 Lens Replacement, LCD Screen: stap 1, afbeelding 2 van 3 Sony Cyber-shot DSC-WX80 Lens Replacement, LCD Screen: stap 1, afbeelding 3 van 3
    • Begin by removing all six 40mm by 10mm black screws holding the outer frame together with the Phillips #00 screwdriver.
  2. Sony Cyber-shot DSC-WX80 Lens Replacement: stap 2, afbeelding 1 van 3 Sony Cyber-shot DSC-WX80 Lens Replacement: stap 2, afbeelding 2 van 3 Sony Cyber-shot DSC-WX80 Lens Replacement: stap 2, afbeelding 3 van 3
    • Remove the free-moving flap near the battery port and store in a safe place.
    • Pry the front cover off gently. Use a plastic opening tool if available.
    • Now pry the back cover off gently, using a plastic opening tool if available.
  3. Sony Cyber-shot DSC-WX80 Lens Replacement: stap 3, afbeelding 1 van 3 Sony Cyber-shot DSC-WX80 Lens Replacement: stap 3, afbeelding 2 van 3 Sony Cyber-shot DSC-WX80 Lens Replacement: stap 3, afbeelding 3 van 3
    • Remove the #00 screw from the right hand side (from the LCD screen side) which is adjacent to the master control dial.
    • Use a spudger or plastic opening tools to pry up the LCD screen and free the two metal tangs on the left side.
    • Lift up two more metal tabs held down by a thin red plastic strap on the right (master control dial) side. Reference the third image.
    • The thin red plastic strap is very fragile.
  4. Sony Cyber-shot DSC-WX80 Lens Replacement: stap 4, afbeelding 1 van 2 Sony Cyber-shot DSC-WX80 Lens Replacement: stap 4, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    • Using a pair of tweezers, remove the blue ribbon from its connection located toward to the top right of the device.
    • Using a pair of tweezers, remove the gold ribbon from its connection located to the right of the removed blue ribbon.
    • Your LCD screen is now removed and you can replace it!
  5. Sony Cyber-shot DSC-WX80 Lens Replacement, Lens: stap 5, afbeelding 1 van 2 Sony Cyber-shot DSC-WX80 Lens Replacement, Lens: stap 5, afbeelding 2 van 2
    • After the LCD screen has been removed there is a black metal plate that can be pulled off revealing the motherboard and the lens.
  6. Sony Cyber-shot DSC-WX80 Lens Replacement: stap 6, afbeelding 1 van 2 Sony Cyber-shot DSC-WX80 Lens Replacement: stap 6, afbeelding 2 van 2
    • To separate the motherboard from the lens there are two ribbon cables that need to be pulled out of their ports using tweezers.
    • Now that the Lens has been removed from the motherboard you can replace it!
Conclusie
3 andere personen hebben deze handleiding voltooid.
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 28
Altijd: 1,452
