Ga door naar hoofdinhoud
Sony Cyber-shot DSC-WX80 LCD Screen Replacement
Wat je nodig hebt
  1. Sony Cyber-shot DSC-WX80 LCD Screen Replacement, LCD Screen: stap 1, afbeelding 1 van 3 Sony Cyber-shot DSC-WX80 LCD Screen Replacement, LCD Screen: stap 1, afbeelding 2 van 3 Sony Cyber-shot DSC-WX80 LCD Screen Replacement, LCD Screen: stap 1, afbeelding 3 van 3
    • Begin by removing all six 40mm by 10mm black screws holding the outer frame together with the Phillips #00 screwdriver.
  2. Sony Cyber-shot DSC-WX80 LCD Screen Replacement: stap 2, afbeelding 1 van 3 Sony Cyber-shot DSC-WX80 LCD Screen Replacement: stap 2, afbeelding 2 van 3 Sony Cyber-shot DSC-WX80 LCD Screen Replacement: stap 2, afbeelding 3 van 3
    • Remove the free-moving flap near the battery port and store in a safe place.
    • Pry the front cover off gently. Use a plastic opening tool if available.
    • Now pry the back cover off gently, using a plastic opening tool if available.
  3. Sony Cyber-shot DSC-WX80 LCD Screen Replacement: stap 3, afbeelding 1 van 3 Sony Cyber-shot DSC-WX80 LCD Screen Replacement: stap 3, afbeelding 2 van 3 Sony Cyber-shot DSC-WX80 LCD Screen Replacement: stap 3, afbeelding 3 van 3
    • Remove the #00 screw from the right hand side (from the LCD screen side) which is adjacent to the master control dial.
    • Use a spudger or plastic opening tools to pry up the LCD screen and free the two metal tangs on the left side.
    • Lift up two more metal tabs held down by a thin red plastic strap on the right (master control dial) side. Reference the third image.
    • The thin red plastic strap is very fragile.
  4. Sony Cyber-shot DSC-WX80 LCD Screen Replacement: stap 4, afbeelding 1 van 2 Sony Cyber-shot DSC-WX80 LCD Screen Replacement: stap 4, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    • Using a pair of tweezers, remove the blue ribbon from its connection located toward to the top right of the device.
    • Using a pair of tweezers, remove the gold ribbon from its connection located to the right of the removed blue ribbon.
    • Your LCD screen is now removed and you can replace it!
Conclusie
4 andere personen hebben deze handleiding voltooid.
2 opmerkingen
Would the wheel be included with the LCD? The wheel on my camera is broken, and I would like to fix/replace it, so should I just order a new LCD screen?
Caleb V. - Antwoord
The replacement includes just the compatible LDC screen and the connector; the wheel is a separate piece.
The LCD comes naked, meaning that the fancy screen protector with black frame is not provided. It is kind of a sticker which shall be detached from the original LCD and re-attached to the new one. It would have been a good idea to include it within the fix tip.
Jose Luis Martínez - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 3
Altijd: 1,855
