Ga door naar hoofdinhoud
Sony Cyber-shot DSC-WX80 Battery Replacement
Wat je nodig hebt
  1. Sony Cyber-shot DSC-WX80 Battery Replacement, Battery: stap 1, afbeelding 1 van 3 Sony Cyber-shot DSC-WX80 Battery Replacement, Battery: stap 1, afbeelding 2 van 3 Sony Cyber-shot DSC-WX80 Battery Replacement, Battery: stap 1, afbeelding 3 van 3
    • Begin by removing all six #00 screws holding the outer chassis together with the Phillips #00 Precision Screwdriver.
    • Remember to keep track of all screws as they are small and very easy to lose
  2. Sony Cyber-shot DSC-WX80 Battery Replacement: stap 2, afbeelding 1 van 3 Sony Cyber-shot DSC-WX80 Battery Replacement: stap 2, afbeelding 2 van 3 Sony Cyber-shot DSC-WX80 Battery Replacement: stap 2, afbeelding 3 van 3
    • Take note of the small free moving flap near the battery port seen in the first of the three photos. Be sure to store the free moving flap in a safe place.
    • Pry the front cover off gently. Use a plastic opening tool if available.
    • Now pry the back cover off gently, using a plastic opening tool if available.
  3. Sony Cyber-shot DSC-WX80 Battery Replacement: stap 3, afbeelding 1 van 1
    • Access where the replacement battery will go indicated by the red square in the photo to your left
    • Now insert your new replacement battery
Conclusie
2 opmerkingen
Why did you not just open the bottom battery door instead of pulling the camera apart?
Kat - Antwoord
I am also suprised to know that I should dis-assemble to replace battery. It maybe a joke.
Chung-Suh Ku - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 16
Altijd: 1,029
