Ga door naar hoofdinhoud
Sony Cyber-shot DSC-WX350 Flash Assembly Replacement
Wat je nodig hebt
  1. Sony Cyber-shot DSC-WX350 Flash Assembly Replacement, Flash Assembly: stap 1, afbeelding 1 van 3 Sony Cyber-shot DSC-WX350 Flash Assembly Replacement, Flash Assembly: stap 1, afbeelding 2 van 3 Sony Cyber-shot DSC-WX350 Flash Assembly Replacement, Flash Assembly: stap 1, afbeelding 3 van 3
    • Remove 6 black Phillips 4 mm screws using the J00 head screwdriver tip from the sides and bottom of top cover.
  2. Sony Cyber-shot DSC-WX350 Flash Assembly Replacement: stap 2, afbeelding 1 van 1
    • Remove the black Phillips 4 mm screw using the J00 head screwdriver tip from inside the battery inclosure.
  3. Sony Cyber-shot DSC-WX350 Flash Assembly Replacement: stap 3, afbeelding 1 van 2 Sony Cyber-shot DSC-WX350 Flash Assembly Replacement: stap 3, afbeelding 2 van 2
    • Use the plastic opening tool to take back cover off. Then take out the LCD screen with your hand.
  4. Sony Cyber-shot DSC-WX350 Flash Assembly Replacement: stap 4, afbeelding 1 van 1
    • Now take the control wheel board out with your hand.
  5. Sony Cyber-shot DSC-WX350 Flash Assembly Replacement: stap 5, afbeelding 1 van 1
    • On the left side of the camera, pull the LCD off the back plate.
    • There will be a ZIF connector by the control wheel, release the connector and remove the LCD.
  6. Sony Cyber-shot DSC-WX350 Flash Assembly Replacement: stap 6, afbeelding 1 van 2 Sony Cyber-shot DSC-WX350 Flash Assembly Replacement: stap 6, afbeelding 2 van 2
    • Remove silver Phillips 4 mm screws using the J00 head screwdriver tip from the metal cover. Once done take the metal cover off with your hands.
  7. Sony Cyber-shot DSC-WX350 Flash Assembly Replacement: stap 7, afbeelding 1 van 3 Sony Cyber-shot DSC-WX350 Flash Assembly Replacement: stap 7, afbeelding 2 van 3 Sony Cyber-shot DSC-WX350 Flash Assembly Replacement: stap 7, afbeelding 3 van 3
    • Using your finger open take off the three zifs.
  8. Sony Cyber-shot DSC-WX350 Flash Assembly Replacement: stap 8, afbeelding 1 van 2 Sony Cyber-shot DSC-WX350 Flash Assembly Replacement: stap 8, afbeelding 2 van 2
    • Use your hand to take out the lens assembly. Then take out the motherboard assembly with your hand.
  9. Sony Cyber-shot DSC-WX350 Flash Assembly Replacement: stap 9, afbeelding 1 van 3 Sony Cyber-shot DSC-WX350 Flash Assembly Replacement: stap 9, afbeelding 2 van 3 Sony Cyber-shot DSC-WX350 Flash Assembly Replacement: stap 9, afbeelding 3 van 3
    • Remove the silver Phillips 4 mm screws using the J00 head screwdriver tip from the metal piece and remove the 4mm screws from the metal piece lining the lens assembly hole.
  10. Sony Cyber-shot DSC-WX350 Flash Assembly Replacement: stap 10, afbeelding 1 van 2 Sony Cyber-shot DSC-WX350 Flash Assembly Replacement: stap 10, afbeelding 2 van 2
    • Grab the top of the camera and take it out. Then grab the flash assembly and slide it out.
Conclusie
4 andere personen hebben deze handleiding voltooid.
Matt Garthwaite
125 Reputatie
1 Handleiding geschreven
IUPUI, Team S1-G1, Wilson Summer 2017 Lid van IUPUI, Team S1-G1, Wilson Summer 2017
IUPUI-WILSON-SU17S1G1
4 Leden
3 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 29
Altijd: 1,820
