Ga door naar hoofdinhoud
Sony Cyber-shot DSC-WX100 Outer Casing Replacement
Wat je nodig hebt
  1. Sony Cyber-shot DSC-WX100 Outer Casing Replacement, Battery: stap 1, afbeelding 1 van 1
    • Open the flap indicated to allow access to the battery slot.
    • The gray switch indicated has to be moved to the right in order to release the flap.
  2. Sony Cyber-shot DSC-WX100 Outer Casing Replacement: stap 2, afbeelding 1 van 1
    • If the old battery is still in the slot, then make sure the camera is turned off prior to removal.
    • If there is a battery currently in the slot, remove by first pulling downwards on the blue component. This will allow you to remove the battery from the slot.
  3. Sony Cyber-shot DSC-WX100 Outer Casing Replacement, Outer Casing: stap 3, afbeelding 1 van 3 Sony Cyber-shot DSC-WX100 Outer Casing Replacement, Outer Casing: stap 3, afbeelding 2 van 3 Sony Cyber-shot DSC-WX100 Outer Casing Replacement, Outer Casing: stap 3, afbeelding 3 van 3
    • Remove all of the 1mm screws using a Philips #000 Screwdriver.
    • Remover the rest of the screws (2mm) from the camera covers using a Phillips #000 Screwdriver.
  4. Sony Cyber-shot DSC-WX100 Outer Casing Replacement: stap 4, afbeelding 1 van 2 Sony Cyber-shot DSC-WX100 Outer Casing Replacement: stap 4, afbeelding 2 van 2
    • Use the plastic opening tool to gently remove the front and back plates of the camera.
  5. Sony Cyber-shot DSC-WX100 Outer Casing Replacement: stap 5, afbeelding 1 van 2 Sony Cyber-shot DSC-WX100 Outer Casing Replacement: stap 5, afbeelding 2 van 2
    • Use a plastic opening tool to gently release the two indicated tabs.
Conclusie
Matthew
583 Reputatie
4 handleidingen geschreven
Michigan Tech, Team 1-9, Lauer Spring 2015 Lid van Michigan Tech, Team 1-9, Lauer Spring 2015
MTU-LAUER-S15S1G9
2 Leden
6 handleidingen geschreven
Één opmerking
Where I can buy the Outer Casing..¿??
ING CHARLY - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 22
Altijd: 848
