Ga door naar hoofdinhoud
Sony Cyber-shot DSC-WX100 Battery Replacement
  1. Sony Cyber-shot DSC-WX100 Battery Replacement, Battery: stap 1, afbeelding 1 van 1
    • Open the flap indicated to allow access to the battery slot.
    • The gray switch indicated has to be moved to the right in order to release the flap.
  2. Sony Cyber-shot DSC-WX100 Battery Replacement: stap 2, afbeelding 1 van 1
    • If the old battery is still in the slot, then make sure the camera is turned off prior to removal.
    • If there is a battery currently in the slot, remove by first pulling downwards on the blue component. This will allow you to remove the battery from the slot.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Peter Prins
262 Reputatie
2 handleidingen geschreven
Michigan Tech, Team 1-9, Lauer Spring 2015 Lid van Michigan Tech, Team 1-9, Lauer Spring 2015
MTU-LAUER-S15S1G9
2 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 16
Altijd: 1,011
