Ga door naar hoofdinhoud
Sony Cyber-shot DSC-W800 Motherboard Replacement
Wat je nodig hebt
  1. Sony Cyber-shot DSC-W800 Motherboard Replacement, Button Board: stap 1, afbeelding 1 van 3 Sony Cyber-shot DSC-W800 Motherboard Replacement, Button Board: stap 1, afbeelding 2 van 3 Sony Cyber-shot DSC-W800 Motherboard Replacement, Button Board: stap 1, afbeelding 3 van 3
    • Remove the five 4.0 mm Phillips #000 screws on the back panel.
  2. Sony Cyber-shot DSC-W800 Motherboard Replacement: stap 2, afbeelding 1 van 2 Sony Cyber-shot DSC-W800 Motherboard Replacement: stap 2, afbeelding 2 van 2
    • Using the Spudger, remove the back panel from the device.
    • The loose piece circled in the picture will most likely fall off the camera housing.
  3. Sony Cyber-shot DSC-W800 Motherboard Replacement: stap 3, afbeelding 1 van 3 Sony Cyber-shot DSC-W800 Motherboard Replacement: stap 3, afbeelding 2 van 3 Sony Cyber-shot DSC-W800 Motherboard Replacement: stap 3, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    Koop
    • Remove the two 2.15mm Phillips #000 screws from the circuit board.
    • Gently pull on the ribbon wire from ZIF connector with the tweezers to remove the button board.
    • Ribbon wires can easily be damaged.
  4. Sony Cyber-shot DSC-W800 Motherboard Replacement, LCD Screen: stap 4, afbeelding 1 van 1
    • Remove the four 3.75 mm Phillips #000 screws from the LCD back panel.
  5. Sony Cyber-shot DSC-W800 Motherboard Replacement: stap 5, afbeelding 1 van 1
    • Lift the back panel and separate the LCD Screen by prying it up.
    • Remove the back panel.
  6. Sony Cyber-shot DSC-W800 Motherboard Replacement: stap 6, afbeelding 1 van 2 Sony Cyber-shot DSC-W800 Motherboard Replacement: stap 6, afbeelding 2 van 2
    Koop
    • Gently pull on the ribbon wire disconnecting from the ZIF connector (connecting the LCD screen to the motherboard) with the tweezers.
    • Ribbon wires can be easily damaged.
  7. Sony Cyber-shot DSC-W800 Motherboard Replacement, Lens: stap 7, afbeelding 1 van 2 Sony Cyber-shot DSC-W800 Motherboard Replacement, Lens: stap 7, afbeelding 2 van 2
    • With plastic opening tool, gently pry loose the front panel.
    • Separate front panel from the camera housing.
  8. Sony Cyber-shot DSC-W800 Motherboard Replacement: stap 8, afbeelding 1 van 3 Sony Cyber-shot DSC-W800 Motherboard Replacement: stap 8, afbeelding 2 van 3 Sony Cyber-shot DSC-W800 Motherboard Replacement: stap 8, afbeelding 3 van 3
    Koop
    • Remove the lens housing by pushing it, from the front, through the housing and lifting it out.
    • Gently pull on the large ribbon wire (connecting the Lens housing to the motherboard via ZIF connector) with the tweezers.
    • Gently pull on the small ribbon wire (connecting the Lens housing to the motherboard) with the tweezers.
    • Be careful not to damage either of the ribbon wires.
  9. Sony Cyber-shot DSC-W800 Motherboard Replacement, Motherboard: stap 9, afbeelding 1 van 1
    • Remove the single 3.75 mm Phillips #000 screw from the base of the motherboard.
  10. Sony Cyber-shot DSC-W800 Motherboard Replacement: stap 10, afbeelding 1 van 1
    • Remove the two 3.5 mm Phillips #000 screws from the secondary board that is attached to the flash bulb.
  11. Sony Cyber-shot DSC-W800 Motherboard Replacement: stap 11, afbeelding 1 van 3 Sony Cyber-shot DSC-W800 Motherboard Replacement: stap 11, afbeelding 2 van 3 Sony Cyber-shot DSC-W800 Motherboard Replacement: stap 11, afbeelding 3 van 3
    Koop
    • Use the tweezers. Move the thick red cable, attached to the secondary board, outside of its place in the camera housing.
    • Gently pull on the red/black wire in order to free the photo lens cylinder from the housing.
    • Remove the secondary board from its position and move it upward, out of the way.
    • From this point on, do not damage the connection between the motherboard and the secondary board.
  12. Sony Cyber-shot DSC-W800 Motherboard Replacement: stap 12, afbeelding 1 van 2 Sony Cyber-shot DSC-W800 Motherboard Replacement: stap 12, afbeelding 2 van 2
    • Using the tweezers, pull the indicator bulb out , freeing it from its position on the housing.
    • Thread the indicator bulb under and through the secondary boards position.
  13. Sony Cyber-shot DSC-W800 Motherboard Replacement: stap 13, afbeelding 1 van 3 Sony Cyber-shot DSC-W800 Motherboard Replacement: stap 13, afbeelding 2 van 3 Sony Cyber-shot DSC-W800 Motherboard Replacement: stap 13, afbeelding 3 van 3
    • Using the tweezers, remove the black/red speaker wire from camera housing.
    • Pry loose and remove the speaker from the camera housing.
    • The speaker is attached with adhesive and must be removed with the spudger and moderate force.
  14. Sony Cyber-shot DSC-W800 Motherboard Replacement: stap 14, afbeelding 1 van 2 Sony Cyber-shot DSC-W800 Motherboard Replacement: stap 14, afbeelding 2 van 2
    • Using the spudger, remove the mini speaker from the housing.
  15. Sony Cyber-shot DSC-W800 Motherboard Replacement: stap 15, afbeelding 1 van 3 Sony Cyber-shot DSC-W800 Motherboard Replacement: stap 15, afbeelding 2 van 3 Sony Cyber-shot DSC-W800 Motherboard Replacement: stap 15, afbeelding 3 van 3
    • Pull up on the bottom-half of the motherboard, slightly removing it from its position in the housing.
    • With enough force, pull up on the top right of the motherboard, pulling it entirely from its position in the housing.
    • Once again, be sure to keep the motherboard and secondary board connection intact.
  16. Sony Cyber-shot DSC-W800 Motherboard Replacement: stap 16, afbeelding 1 van 1
    • Once apart, completely separate motherboard from the housing.
Conclusie
Thomas Campo
809 Reputatie
4 handleidingen geschreven
USF Tampa, Team 17-5, Blackwell Winter 2016 Lid van USF Tampa, Team 17-5, Blackwell Winter 2016
USFT-BLACKWELL-W16S17G5
5 Leden
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 28
Altijd: 1,284
