Ga door naar hoofdinhoud
Sony Cyber-shot DSC-W800 Lens Replacement
Wat je nodig hebt
  1. Sony Cyber-shot DSC-W800 Lens Replacement, Button Board: stap 1, afbeelding 1 van 3 Sony Cyber-shot DSC-W800 Lens Replacement, Button Board: stap 1, afbeelding 2 van 3 Sony Cyber-shot DSC-W800 Lens Replacement, Button Board: stap 1, afbeelding 3 van 3
    • Remove the five 4.0 mm Phillips #000 screws on the back panel.
  2. Sony Cyber-shot DSC-W800 Lens Replacement: stap 2, afbeelding 1 van 2 Sony Cyber-shot DSC-W800 Lens Replacement: stap 2, afbeelding 2 van 2
    • Using the Spudger, remove the back panel from the device.
    • The loose piece circled in the picture will most likely fall off the camera housing.
  3. Sony Cyber-shot DSC-W800 Lens Replacement: stap 3, afbeelding 1 van 3 Sony Cyber-shot DSC-W800 Lens Replacement: stap 3, afbeelding 2 van 3 Sony Cyber-shot DSC-W800 Lens Replacement: stap 3, afbeelding 3 van 3
    • Remove the two 2.15mm Phillips #000 screws from the circuit board.
    • Gently pull on the ribbon wire from ZIF connector with the tweezers to remove the button board.
    • Ribbon wires can easily be damaged.
  4. Sony Cyber-shot DSC-W800 Lens Replacement, LCD Screen: stap 4, afbeelding 1 van 1
    • Remove the four 3.75 mm Phillips #000 screws from the LCD back panel.
  5. Sony Cyber-shot DSC-W800 Lens Replacement: stap 5, afbeelding 1 van 1
    • Lift the back panel and separate the LCD Screen by prying it up.
    • Remove the back panel.
  6. Sony Cyber-shot DSC-W800 Lens Replacement: stap 6, afbeelding 1 van 2 Sony Cyber-shot DSC-W800 Lens Replacement: stap 6, afbeelding 2 van 2
    • Gently pull on the ribbon wire disconnecting from the ZIF connector (connecting the LCD screen to the motherboard) with the tweezers.
    • Ribbon wires can be easily damaged.
  7. Sony Cyber-shot DSC-W800 Lens Replacement, Lens: stap 7, afbeelding 1 van 2 Sony Cyber-shot DSC-W800 Lens Replacement, Lens: stap 7, afbeelding 2 van 2
    • With plastic opening tool, gently pry loose the front panel.
    • Separate front panel from the camera housing.
  8. Sony Cyber-shot DSC-W800 Lens Replacement: stap 8, afbeelding 1 van 3 Sony Cyber-shot DSC-W800 Lens Replacement: stap 8, afbeelding 2 van 3 Sony Cyber-shot DSC-W800 Lens Replacement: stap 8, afbeelding 3 van 3
    • Remove the lens housing by pushing it, from the front, through the housing and lifting it out.
    • Gently pull on the large ribbon wire (connecting the Lens housing to the motherboard via ZIF connector) with the tweezers.
    • Gently pull on the small ribbon wire (connecting the Lens housing to the motherboard) with the tweezers.
    • Be careful not to damage either of the ribbon wires.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Thomas Campo
788 Reputatie
4 handleidingen geschreven
USF Tampa, Team 17-5, Blackwell Winter 2016 Lid van USF Tampa, Team 17-5, Blackwell Winter 2016
USFT-BLACKWELL-W16S17G5
5 Leden
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 13
Afgelopen 30 dagen: 45
Altijd: 4,319
