Ga door naar hoofdinhoud
Sony Cyber-shot DSC-W800 Button Board Replacement
Wat je nodig hebt
  1. Sony Cyber-shot DSC-W800 Button Board Replacement, Button Board: stap 1, afbeelding 1 van 3 Sony Cyber-shot DSC-W800 Button Board Replacement, Button Board: stap 1, afbeelding 2 van 3 Sony Cyber-shot DSC-W800 Button Board Replacement, Button Board: stap 1, afbeelding 3 van 3
    • Remove the five 4.0 mm Phillips #000 screws on the back panel.
  2. Sony Cyber-shot DSC-W800 Button Board Replacement: stap 2, afbeelding 1 van 2 Sony Cyber-shot DSC-W800 Button Board Replacement: stap 2, afbeelding 2 van 2
    • Using the Spudger, remove the back panel from the device.
    • The loose piece circled in the picture will most likely fall off the camera housing.
  3. Sony Cyber-shot DSC-W800 Button Board Replacement: stap 3, afbeelding 1 van 3 Sony Cyber-shot DSC-W800 Button Board Replacement: stap 3, afbeelding 2 van 3 Sony Cyber-shot DSC-W800 Button Board Replacement: stap 3, afbeelding 3 van 3
    • Remove the two 2.15mm Phillips #000 screws from the circuit board.
    • Gently pull on the ribbon wire from ZIF connector with the tweezers to remove the button board.
    • Ribbon wires can easily be damaged.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Thomas Campo
788 Reputatie
4 handleidingen geschreven
USF Tampa, Team 17-5, Blackwell Winter 2016 Lid van USF Tampa, Team 17-5, Blackwell Winter 2016
USFT-BLACKWELL-W16S17G5
5 Leden
5 handleidingen geschreven
4 opmerkingen
Thanks for this - was spot on and allowed me to easily fix the problem I was experiencing!
jimbradshaw - Antwoord
follow the step camera button loosen a bit unstuck but camera still stock on language setting and do not budge
Trisha Amable Girlfridayz - Antwoord
follow the step the button are unstuck but the camera display still stock on language setting
i need a new strip, because old strip was damaged.
moonbhaai@gmail.com
Naveed Shoukat - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 22
Afgelopen 30 dagen: 46
Altijd: 2,378
