Inleiding
This will help solve a lot of black screen problems, as you should be able to see if the ribbon is connected or the LCD screen is damaged. Be careful with the ribbons.
Wat je nodig hebt
Open the battery/memory card door and remove the 6 screws (.35cm) with a Philips 000 screwdriver. There will be two screws on the left and right sides, and two on the bottom.
Flip over the control board then use tweezers to pull out the ribbon connecting the circuit board to the motherboard.
Use tweezers to remove the ribbon that is connected from the LCD screen to the camera by pulling the part that is folded under, out.
Één andere persoon heeft deze handleiding voltooid.
