Inleiding
This could be a solution to the buttons on the back of the camera not working. This is an easy replacement. Just be careful with the ribbons.
Onderdelen
Geen onderdelen nodig.
  1. Open the battery/memory card door and remove the 6 screws (.35cm) with a Philips 000 screwdriver. There will be two screws on the left and right sides, and two on the bottom. Open the battery/memory card door and remove the 6 screws (.35cm) with a Philips 000 screwdriver. There will be two screws on the left and right sides, and two on the bottom. Open the battery/memory card door and remove the 6 screws (.35cm) with a Philips 000 screwdriver. There will be two screws on the left and right sides, and two on the bottom.
    • Open the battery/memory card door and remove the 6 screws (.35cm) with a Philips 000 screwdriver. There will be two screws on the left and right sides, and two on the bottom.
  2. Take off the front part of the case with a plastic opening tool. Take off the front part of the case with a plastic opening tool. Take off the front part of the case with a plastic opening tool.
    • Take off the front part of the case with a plastic opening tool.
  3. Gratis verzending van alle bestellingen van meer dan US$ 100,00 of met een Pro Tech Toolkit!
    Doorblader onze winkel
  4. Pull off the two silver side pieces on the left and right sides. Pull off the two silver side pieces on the left and right sides.
    • Pull off the two silver side pieces on the left and right sides.
  5. Remove the main back piece. It should easily lift off. Remove the main back piece. It should easily lift off.
    • Remove the main back piece. It should easily lift off.
  6. Unscrew the .45cm screw located on the upper right corner on the back of the camera. Once the screw is off, use the spudger and unclip the piece holding the top down on the upper left on the front of the camera. It should lift off with ease. Unscrew the .45cm screw located on the upper right corner on the back of the camera. Once the screw is off, use the spudger and unclip the piece holding the top down on the upper left on the front of the camera. It should lift off with ease. Unscrew the .45cm screw located on the upper right corner on the back of the camera. Once the screw is off, use the spudger and unclip the piece holding the top down on the upper left on the front of the camera. It should lift off with ease.
    • Unscrew the .45cm screw located on the upper right corner on the back of the camera. Once the screw is off, use the spudger and unclip the piece holding the top down on the upper left on the front of the camera. It should lift off with ease.
  7. Flip over the control board then use tweezers to pull out the ribbon connecting the circuit board to the motherboard. Flip over the control board then use tweezers to pull out the ribbon connecting the circuit board to the motherboard.
    • Flip over the control board then use tweezers to pull out the ribbon connecting the circuit board to the motherboard.
Conclusie
Douglas Howe
474 Reputatie
4 handleidingen geschreven
USF Tampa, Team 9-4, Blackwell Winter 2015 Lid van USF Tampa, Team 9-4, Blackwell Winter 2015
USFT-BLACKWELL-W15S9G4
3 Leden
6 handleidingen geschreven
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 0
Afgelopen 30 Dagen: 0
Altijd: 288
