Ga door naar hoofdinhoud
Sony Cyber-shot DSC-W55 Front Case Replacement
Wat je nodig hebt
  1. Sony Cyber-shot DSC-W55 Front Case Replacement, Battery: stap 1, afbeelding 1 van 2 Sony Cyber-shot DSC-W55 Front Case Replacement, Battery: stap 1, afbeelding 2 van 2
    • Slide the battery cover in the direction the arrow points.
    • Pull the battery cover towards you.
  2. Sony Cyber-shot DSC-W55 Front Case Replacement: stap 2, afbeelding 1 van 2 Sony Cyber-shot DSC-W55 Front Case Replacement: stap 2, afbeelding 2 van 2
    • Flick the blue switch for the battery to pop out.
    • Remove the battery from the camera.
  3. Sony Cyber-shot DSC-W55 Front Case Replacement, Back Case: stap 3, afbeelding 1 van 2 Sony Cyber-shot DSC-W55 Front Case Replacement, Back Case: stap 3, afbeelding 2 van 2
    • Using the Phillips #00 Screwdriver, remove the two screws from the caution panel.
    • Remove that panel.
    • Careful for falling pieces.
  4. Sony Cyber-shot DSC-W55 Front Case Replacement: stap 4, afbeelding 1 van 2 Sony Cyber-shot DSC-W55 Front Case Replacement: stap 4, afbeelding 2 van 2
    • Remove the screw with a Phillips #00 screwdriver from the left side of the camera (with '3x optical zoom' engraved on the side panel).
  5. Sony Cyber-shot DSC-W55 Front Case Replacement: stap 5, afbeelding 1 van 1
    • Remove the screw using the Phillips #00 screwdriver from the bottom of the camera, closest to the back cover.
  6. Sony Cyber-shot DSC-W55 Front Case Replacement: stap 6, afbeelding 1 van 2 Sony Cyber-shot DSC-W55 Front Case Replacement: stap 6, afbeelding 2 van 2
    • Gently remove the back cover.
    • It may be a bit stiff, so use some force to remove it. Proceed with caution.
  7. Sony Cyber-shot DSC-W55 Front Case Replacement, Front Case: stap 7, afbeelding 1 van 1
    • Remove the screw using a Phillips #00 screwdriver on the right side (where the caution panel used to be).
  8. Sony Cyber-shot DSC-W55 Front Case Replacement: stap 8, afbeelding 1 van 3 Sony Cyber-shot DSC-W55 Front Case Replacement: stap 8, afbeelding 2 van 3 Sony Cyber-shot DSC-W55 Front Case Replacement: stap 8, afbeelding 3 van 3
    • Remove the small screw using a Phillips #00 screwdriver on the bottom of the camera attached to the front cover.
    • Gently remove the front cover.
    • Put a little force to pop off the case. Proceed with caution.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Andrew Carter
202 Reputatie
2 handleidingen geschreven
Cal Poly, Team 9-20, Regan Fall 2010 Lid van Cal Poly, Team 9-20, Regan Fall 2010
CPSU-REGAN-F10S9G20
5 Leden
18 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 13
Altijd: 3,375
