Inleiding
We are going to explain the steps needed and what is necessary in order to replace a broken front cover for this camera.
Wat je nodig hebt
Slide the battery cover in the direction the arrow points.
Pull the battery cover towards you.
Using the Phillips #00 Screwdriver, remove the two screws from the caution panel.
Remove that panel.
Remove the screw using a Phillips #00 screwdriver on the right side (where the caution panel used to be).
Één andere persoon heeft deze handleiding voltooid.
