Ga door naar hoofdinhoud
Inleiding
Disassembling the back cover of the camera so that we can repair components from the inside.
Onderdelen
Geen onderdelen opgegeven.
  1. Slide the battery cover in the direction the arrow points. Pull the battery cover towards you.
    • Slide the battery cover in the direction the arrow points.
    • Pull the battery cover towards you.
  2. Flick the blue switch for the battery to pop out. Remove the battery from the camera.
    • Flick the blue switch for the battery to pop out.
    • Remove the battery from the camera.
  3. iPhone Batterij Fix Kits
    Slechts $29.99
    Buy Now
    Slechts $29.99
    Buy Now
  4. Using the Phillips #00 Screwdriver, remove the two screws from the caution panel. Remove that panel.
    • Using the Phillips #00 Screwdriver, remove the two screws from the caution panel.
    • Remove that panel.
    • Careful for falling pieces.
  5. Remove the screw with a Phillips #00 Screwdriver from the right side of the camera (with '3x optical zoom' engraved on the side panel). Remove that panel.
    • Remove the screw with a Phillips #00 Screwdriver from the right side of the camera (with '3x optical zoom' engraved on the side panel).
  6. Remove the screw using the Phillips #00 Screwdriver from the bottom the camera, closest to the back cover.
    • Remove the screw using the Phillips #00 Screwdriver from the bottom the camera, closest to the back cover.
  7. Gently remove the back cover. It may be a bit stiff, so use some force to remove it. Proceed with caution.
    • Gently remove the back cover.
    • It may be a bit stiff, so use some force to remove it. Proceed with caution.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
kkfong91
293 Reputatie
2 handleidingen geschreven
Cal Poly, Team 9-20, Regan Fall 2010 Lid van Cal Poly, Team 9-20, Regan Fall 2010
CPSU-REGAN-F10S9G20
5 Leden
9 handleidingen geschreven
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 Uren: 1
Afgelopen 7 Dagen: 1
Afgelopen 30 Dagen: 8
Altijd: 3,290
