Inleiding
We will explain the steps needed to replace an AV port.
Wat je nodig hebt
Slide the battery cover in the direction the arrow points.
Pull the battery cover towards you.
Using the Phillips #00 Screwdriver, remove the two screws from the caution panel.
Remove that panel.
Remove the screw using a Phillips #00 screwdriver on the left side (where the "3x optical zoom" panel use to be).
Flip the black secure locks off. Tweezers may be necessary.
Detach the two orange cables.
Remove the black screw using a Phillips #00 Screwdriver on the motherboard.
Verify the orange cables from the motherboard are removed from the LCD screen.
Lift the LCD screen off the hinge.
Verify that the orange cables from the top piece are removed from the motherboard.
Remove the screw using a Phillips #00 Screwdriver on the upper part of the back side.
Remove the screw using a Phillips #00 Screwdriver connected to the AV port.
Flip the camera to its back, gently pull the bottom cover.
Één andere persoon heeft deze handleiding voltooid.
