Ga door naar hoofdinhoud
Sony Cyber-shot DSC-W50 Front Case Replacement
Wat je nodig hebt
  1. Sony Cyber-shot DSC-W50 Front Case Replacement, Front Case: stap 1, afbeelding 1 van 3 Sony Cyber-shot DSC-W50 Front Case Replacement, Front Case: stap 1, afbeelding 2 van 3 Sony Cyber-shot DSC-W50 Front Case Replacement, Front Case: stap 1, afbeelding 3 van 3
    • Remove the rightmost screw on the bottom of the camera with the screwdriver.
    • Remove the bottom left screw with the screwdriver.
    • Remove the top left screw with the screwdriver.
  2. Sony Cyber-shot DSC-W50 Front Case Replacement: stap 2, afbeelding 1 van 1
    • Flip the camera over to expose its right side.
    • Remove the screw with the screwdriver.
  3. Sony Cyber-shot DSC-W50 Front Case Replacement: stap 3, afbeelding 1 van 2 Sony Cyber-shot DSC-W50 Front Case Replacement: stap 3, afbeelding 2 van 2
    • Flip the camera to expose the left side with the wrist strap.
    • Remove the top screw with the screwdriver.
    • Remove the bottom screw with the screwdriver.
  4. Sony Cyber-shot DSC-W50 Front Case Replacement: stap 4, afbeelding 1 van 1
    • Lift the side panel of the camera up to release the front case.
  5. Sony Cyber-shot DSC-W50 Front Case Replacement: stap 5, afbeelding 1 van 1
    • Lift the front case up gently to remove it completely.
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 27
Altijd: 756
