Ga door naar hoofdinhoud
Inleiding
This guide will show you how to access the LCD screen in order to repair or replace the screen.
Onderdelen
Geen onderdelen opgegeven.
  1. Remove Memory Stick Pro from the card reader slot on the bottom of the camera.
    • Remove Memory Stick Pro from the card reader slot on the bottom of the camera.
    • Remove both batteries.
  2. Remove the single visible screw from both sides of the camera. Remove the two screws that are adjacent to the warning label, which is on the underside of the camera.
    • Remove the single visible screw from both sides of the camera.
    • Remove the two screws that are adjacent to the warning label, which is on the underside of the camera.
    • Do NOT remove all four screws from the bottom.
  3. Gently remove the back cover from the camera. The first time the case is removed, it will be stiff. Be patient and gently rock the cover back and forth until it slides free.
    • Gently remove the back cover from the camera.
    • The first time the case is removed, it will be stiff. Be patient and gently rock the cover back and forth until it slides free.
  4. Remove the two screws holding the circuit board down. Remove the two screws holding the circuit board down.
    • Remove the two screws holding the circuit board down.
  5. Detach the orange cable from the board.
    • Detach the orange cable from the board.
    • Use a thin object, like a paperclip, to gently pry the cable off the connector.
  6. The LCD screen sits in two slots; one on the bottom, and one on the left edge. Slide LCD screen from the two slots.
    • The LCD screen sits in two slots; one on the bottom, and one on the left edge.
    • Slide LCD screen from the two slots.
    • Do not attempt to completely remove the screen, as it is still attached to the camera.
  7. To remove the LCD screen, detach the orange cable from the board. If needed, replace the LCD screen. If needed, replace the LCD screen.
    • To remove the LCD screen, detach the orange cable from the board.
    • If needed, replace the LCD screen.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Thomas
124 Reputatie
6 handleidingen geschreven
Cal Poly, Team 15-50, Garner Spring 2010 Lid van Cal Poly, Team 15-50, Garner Spring 2010
CPSU-GARNER-S10S15G50
5 Leden
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 Uren: 3
Afgelopen 7 Dagen: 9
Afgelopen 30 Dagen: 25
Altijd: 10,462
