Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Take your screwdriver and remove the four silver bottom screws of the camera.
On the right side of the camera, remove the two silver screws using the screwdriver.
On the left side of the camera, remove the two silver screws using the screwdriver.
Gently detach the back cover by holding onto both sides of the camera and pulling them apart.
After detaching the back cover, carefully pull it off.
The back cover should now be separated from the camera.
Remove the two screws at the top of the camera casing.
After removing the screws, gently pop open the plastic piece, as shown by firmly pulling it with your fingers.
After popping open the plastic piece, there is a screw that needs to be removed.
Remove the screw connecting the front casing to the electrical components.
On the casing on the opposite side of the camera, gently loosen and remove the casing by firmly pulling with your fingers.
Remove the two screws connecting the front casing to the electrical components using a screwdriver.
Gently loosen the front casing by gently using your fingers to pull it apart.
Fully remove the front casing from the camera and set it aside.
5 andere personen hebben deze handleiding voltooid.
