Ga door naar hoofdinhoud
Sony Cyber-shot DSC-TX7 Front Cover Replacement
Wat je nodig hebt
  1. Sony Cyber-shot DSC-TX7 Front Cover Replacement, Battery: stap 1, afbeelding 1 van 2 Sony Cyber-shot DSC-TX7 Front Cover Replacement, Battery: stap 1, afbeelding 2 van 2
    • The battery compartment is located on the bottom of camera.
    • Move the slider from the 'lock' position to the 'open' position.
  2. Sony Cyber-shot DSC-TX7 Front Cover Replacement: stap 2, afbeelding 1 van 3 Sony Cyber-shot DSC-TX7 Front Cover Replacement: stap 2, afbeelding 2 van 3 Sony Cyber-shot DSC-TX7 Front Cover Replacement: stap 2, afbeelding 3 van 3
    • Battery not shown.
    • Pull battery from compartment.
    • Insert newly charged battery into compartment, as shown in diagram (located in compartment).
    • Shut compartment door.
    • Move the slider back to the 'lock' position.
  3. Sony Cyber-shot DSC-TX7 Front Cover Replacement, Front Cover: stap 3, afbeelding 1 van 1
    • Use the Phillips #00 screwdriver to remove the 4mm length screws. There are 6 screws total.
  4. Sony Cyber-shot DSC-TX7 Front Cover Replacement: stap 4, afbeelding 1 van 3 Sony Cyber-shot DSC-TX7 Front Cover Replacement: stap 4, afbeelding 2 van 3 Sony Cyber-shot DSC-TX7 Front Cover Replacement: stap 4, afbeelding 3 van 3
    • The 4 mm length screws are located on each side and on the bottom of the camera.
    • 2 screws on each side (4 total).
    • 2 screws on bottom.
  5. Sony Cyber-shot DSC-TX7 Front Cover Replacement: stap 5, afbeelding 1 van 1
    • Gently pry around the front cover using the plastic opening tool.
    • Carefully separate front cover from body of camera.
  6. Sony Cyber-shot DSC-TX7 Front Cover Replacement: stap 6, afbeelding 1 van 1
    • The front cover is now removed from the camera and the internal hardware is now visible.
    • They front cover will still be connected by a ribbon. Be careful not to break the ribbon.
Conclusie
Leslie Mundell
411 Reputatie
4 handleidingen geschreven
Michigan Tech, Team 1-8, Lauer Spring 2015 Lid van Michigan Tech, Team 1-8, Lauer Spring 2015
MTU-LAUER-S15S1G8
2 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 5
Altijd: 333
