Ga door naar hoofdinhoud
Sony Cyber-shot DSC-TX100V OLED/LCD Assembly Replacement
Wat je nodig hebt
  1. Sony Cyber-shot DSC-TX100V OLED/LCD Assembly Replacement, OLED/LCD Assembly: stap 1, afbeelding 1 van 3 Sony Cyber-shot DSC-TX100V OLED/LCD Assembly Replacement, OLED/LCD Assembly: stap 1, afbeelding 2 van 3 Sony Cyber-shot DSC-TX100V OLED/LCD Assembly Replacement, OLED/LCD Assembly: stap 1, afbeelding 3 van 3
    • Remove the battery
    • Remove the five 2.5mm Philips #0 screws.
    • Remove the one 2.5mm Philips #0 screw inside the HDMI case.
  2. Sony Cyber-shot DSC-TX100V OLED/LCD Assembly Replacement: stap 2, afbeelding 1 van 1
    • Gently work and pull the front cover off of the camera
  3. Sony Cyber-shot DSC-TX100V OLED/LCD Assembly Replacement: stap 3, afbeelding 1 van 1
    • Gently pull and disconnect the ribbon cable connecting the front cover to the main body
  4. Sony Cyber-shot DSC-TX100V OLED/LCD Assembly Replacement: stap 4, afbeelding 1 van 3 Sony Cyber-shot DSC-TX100V OLED/LCD Assembly Replacement: stap 4, afbeelding 2 van 3 Sony Cyber-shot DSC-TX100V OLED/LCD Assembly Replacement: stap 4, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    iSesamo Opening Tool
    $9.99
    Koop
    • Using an iSesamo Opening Tool, Spudger, or flat dull opening tool, gently pry off the cover of the OLED/LCD assembly.
    • Take care of the tab/clip at the bottom, it can be a little tricky.
    • iSesamo Opening Tool is highly recommended
  5. Sony Cyber-shot DSC-TX100V OLED/LCD Assembly Replacement: stap 5, afbeelding 1 van 2 Sony Cyber-shot DSC-TX100V OLED/LCD Assembly Replacement: stap 5, afbeelding 2 van 2
    • Remove the copper phillips screw holding the HDMI mounting plate and detach the mounting plate.
  6. Sony Cyber-shot DSC-TX100V OLED/LCD Assembly Replacement: stap 6, afbeelding 1 van 3 Sony Cyber-shot DSC-TX100V OLED/LCD Assembly Replacement: stap 6, afbeelding 2 van 3 Sony Cyber-shot DSC-TX100V OLED/LCD Assembly Replacement: stap 6, afbeelding 3 van 3
    $9.99
    Koop
    • Using an iSesamo Opening Tool, Spudger, or flat dull opening tool, gently pry the OLED/LCD assembly from the adhesive strip on the main body.
    • Note: where the adhesive strip is located.
    • Turn the device over and remove the clear tape and black tape.
    • Important: Save the clear and black tape, they will be used for the replacement unit.
  7. Sony Cyber-shot DSC-TX100V OLED/LCD Assembly Replacement: stap 7, afbeelding 1 van 1
    • Gently pull the small flat ribbon cable from the main body
    • In order to disconnect the large flat ribbon cable, you need to flip up the black ribbon clamp located on the main body where the socket is located
  8. Sony Cyber-shot DSC-TX100V OLED/LCD Assembly Replacement: stap 8, afbeelding 1 van 1
    • Reattach new display, and reconnect all components
    • Test camera to ensure the new screen is working
    • Congrats!
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Tim
2.163 Reputatie
2 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 16
Altijd: 4,312
