Ga door naar hoofdinhoud
Sony Cyber-shot DSC-T9 LCD Replacement
Wat je nodig hebt
  1. Sony Cyber-shot DSC-T9 LCD Replacement, Battery: stap 1, afbeelding 1 van 1
    • The battery cover is located on the right side of the camera.
    • Slide the cover to expose the battery.
  2. Sony Cyber-shot DSC-T9 LCD Replacement: stap 2, afbeelding 1 van 1
    • Ensure that the battery lines up properly with the slot in the camera.
    • Slide battery in.
    • Slide cover closed.
    • Battery not shown
  3. Sony Cyber-shot DSC-T9 LCD Replacement, Front Cover: stap 3, afbeelding 1 van 3 Sony Cyber-shot DSC-T9 LCD Replacement, Front Cover: stap 3, afbeelding 2 van 3 Sony Cyber-shot DSC-T9 LCD Replacement, Front Cover: stap 3, afbeelding 3 van 3
    • Remove screws from outside of camera. There are 6 screws total.
    • 3 screws on underside.
    • 1 screw on right side, near battery cover.
    • 2 screws on left side.
  4. Sony Cyber-shot DSC-T9 LCD Replacement: stap 4, afbeelding 1 van 1
    • Use screwdriver to remove screws.
  5. Sony Cyber-shot DSC-T9 LCD Replacement: stap 5, afbeelding 1 van 1
    • Gently pull the front cover off of the main camera.
    • All of the inner parts of the camera are attached to the back screen.
  6. Sony Cyber-shot DSC-T9 LCD Replacement: stap 6, afbeelding 1 van 1
    • The front cover is now removed from the camera and the internal hardware is now exposed.
  7. Sony Cyber-shot DSC-T9 LCD Replacement, Back Cover: stap 7, afbeelding 1 van 1
    • This is the camera without the front cover.
  8. Sony Cyber-shot DSC-T9 LCD Replacement: stap 8, afbeelding 1 van 1
    • Remove tripod piece located at the bottom of the camera. This piece should slide out with ease.
  9. Sony Cyber-shot DSC-T9 LCD Replacement: stap 9, afbeelding 1 van 3 Sony Cyber-shot DSC-T9 LCD Replacement: stap 9, afbeelding 2 van 3 Sony Cyber-shot DSC-T9 LCD Replacement: stap 9, afbeelding 3 van 3
    • Slide open the top panel. This is located on the top of the camera, where the power button and shutter button are.
  10. Sony Cyber-shot DSC-T9 LCD Replacement: stap 10, afbeelding 1 van 3 Sony Cyber-shot DSC-T9 LCD Replacement: stap 10, afbeelding 2 van 3 Sony Cyber-shot DSC-T9 LCD Replacement: stap 10, afbeelding 3 van 3
    • Pull apart the inner hardware from the back case by prying on the left side.
  11. Sony Cyber-shot DSC-T9 LCD Replacement: stap 11, afbeelding 1 van 1
    • Remove the back cover.
  12. Sony Cyber-shot DSC-T9 LCD Replacement: stap 12, afbeelding 1 van 1
    • The back cover is now removed from the internal hardware.
  13. Sony Cyber-shot DSC-T9 LCD Replacement, LCD: stap 13, afbeelding 1 van 1
    • Use the spudger to pry the LCD from the camera.
  14. Sony Cyber-shot DSC-T9 LCD Replacement: stap 14, afbeelding 1 van 1
    • The LCD is now removed from the camera, although attached by a ribbon at the bottom of the camera.
  15. Sony Cyber-shot DSC-T9 LCD Replacement: stap 15, afbeelding 1 van 2 Sony Cyber-shot DSC-T9 LCD Replacement: stap 15, afbeelding 2 van 2
    • Flip camera to other side.
    • Use tweezers to peel off black sticker, located in middle of the motherboard.
  16. Sony Cyber-shot DSC-T9 LCD Replacement: stap 16, afbeelding 1 van 2 Sony Cyber-shot DSC-T9 LCD Replacement: stap 16, afbeelding 2 van 2
    • Use pry stick to pop out LCD connector ribbon, also called the ZIF connector.
  17. Sony Cyber-shot DSC-T9 LCD Replacement: stap 17, afbeelding 1 van 1
    • The LCD is now removed from the camera.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Stephannie Allen
255 Reputatie
10 handleidingen geschreven
Clemson, Team 13-1, Benson Spring 2013 Lid van Clemson, Team 13-1, Benson Spring 2013
CLEM-BENSON-S13S13G1
4 Leden
20 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 13
Altijd: 1,145
